Discussion topic: Glass tv without sky
Message posted on 18 Jun 2024 10:53 AM
I got sky glass with sky sub for 18 months tv worked great very happy then my 18 months was up so cancelled my sub now the tv has many issues like not turning on for like an hour then when it does turn on get the home screen then go to watch something or open an app like netflix apple tv or prime disney etc the tv then goes to a black screen as you can guess its very annoying when the tv does work i then cant turn the tv up or down now im left thinking is this a con if i never cancelled my sky sub then eould the tv be working great as it was before when my sub was up n running just wondering has anyone else going though this after cancelling the sky
Message posted on 18 Jun 2024 11:55 AM - last edited: 18 Jun 2024 12:05 PM
Re: Glass tv without sky
Clearly it would be running differently because Glass is intended to be a delivery platform for Sky subscription service: whatever they choose to claim, it's absolutely not a standard smart television set.
It's perhaps worth noting that the hardware itself has a 24 month warranty, although it's somewhat unclear how this can be claimed when there's no longer a subscription in place.
Message posted on 19 Jun 2024 08:26 AM
Running differntly is not same as it not working correctly without the sky sub its just a normal tv you get the freeview via antenna and then you have a great platform for the apps i asked because i was wondering if anyone else has had the same issues your comment is just common sense but you did not seem to get the question that or you didnt read it correctly
Message posted on 19 Jun 2024 08:36 AM - last edited: 19 Jun 2024 08:40 AM
@Paulo123456789 Glass TV do not support, only TVs that support the Freeview specification get Freeview, what Glass TVs get via the aerial is DTT😉
Message posted on 19 Jun 2024 08:39 AM
@Paulo123456789 wrote:Running differntly is not same as it not working correctly without the sky sub its just a normal tv you get the freeview via antenna and then you have a great platform for the apps i asked because i was wondering if anyone else has had the same issues your comment is just common sense but you did not seem to get the question that or you didnt read it correctly
Others have used the Glass TV without a subscription with varying degrees of success🤔
Message posted on 19 Jun 2024 11:34 AM
Yes I must admit I haven't actually plugged in the antenna 😂 I just assumed it was freeview etc I mostly just use apps with subs and decided it was pointless paying for sky when I wasn't actually watching it I was mainly Apple Disney prime Netflix.. I just found it weird that all apps n tv was working great now that I haven't got sky subscription it doesn't was wondering 🤔 if maybe the sky subscription also included important updates for tv to work correctly or if it didn't make a difference because if it's not the case then obviously I need to contact someone to repair tv as stated on the post what the tv is now doing
Message posted on 19 Jun 2024 11:49 AM - last edited: 19 Jun 2024 11:54 AM
Now that you have cancelled your Sky TV subscription service you will receive a replacement remote with direct link buttons.to YouTube and Netflix, so that underlines that streaming services are supposed to work without a Sky TV subscription😉
Note... to activate the DTT aerial functionality you have to disconnect the Glass TV from the internet ... it was too much of a programming challenge for Sky to allow App access and DTT access conveniently on a Glass TV without a Sky TV subscription🤔
