8
This discussion topic has been answered Discussion topic: Freeze Frame
This message was authored by: Leonard6
Freeze Frame
How can I prevent my Sky Glass picture from freezing, stuttering and buffering?
This message was authored by: Fothergill1 Answer
Re: Freeze Frame
Hi @Leonard6One of the main reasons for freezing is the quality and speed of the Wi-Fi signal being received at the TV/puck and not that being received at the router.  This can be checked with the Netflix App (Get help > Check network) and is often much less than you might expect. The minimum speeds  recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
These speeds assume there is nothing else using up your bandwidth.
If your speed at the TV is borderline try connecting via Ethernet cable. If this is not practical you can use powerline adapters (about £35 at Amazon). Note the Ethernet port on the Glass TV (& pucks) only supports 100mbps so don't waste money on the more expensive 1gb powerline adapters
Re: Freeze Frame
HD = 25mbps
UHD = 30mbps
Avatar for Leonard6
Re: Freeze Frame
Thanks for the advice
Avatar for Leonard6
To HD or Not to HD
How do I change the HD settings on Sky Glass so as to view in Standard Definition rather than High Definition?
Avatar for Leonard6
NormalTV
When watching the normal TV channels (BBC, Gold, Dave, etc), how can I view them in Standard Definition rather than High Definition?
Re: NormalTV
@Leonard6  If you have Glass TV (where you have posted) there are no SD variants of these channels, what woud younwant to watch SD on a UHD set?
Avatar for Leonard6
Re: NormalTV
I thought I might get less buffering and picture distortion when watching SD as opposed to HD.
Re: NormalTV
@Leonard6  Buffering and pixelation is normally due to weak or poor wifi.
On your Glass TV go to the Netflix app - Get Help - Network connection, run the connection test, what speed is being reported?
For Glass Live Channels you need at least 25mbos for HD & 35mbps for UHD
You also raised the same question on the 18th Marcha nd were provided with the amswer, did you not folow that advise?
Edit:  Your latest thread has been removed as you have basically asked the same question, please don't create multiple threads as this can be seen as spamming.
Re: Freeze Frame
Are you connected via WiFi or Ethernet cable between the TV and router?
If it's by WiFi, this could be the issue. I found with my Glass that the WiFi would lose connection quite frequently. I switched to an Ethernet connection and have had no issues with freezing, buffering etc.
