2
This discussion topic has been answered Discussion topic: Discovery plus not working after changing package
This message was authored by: Jody2
We have just moved from sky q to sky glass and our discovery plus app is now not working - it is saying contact you provider to find out how to watch.
any ideas how to fix?
This message was authored by: Fothergill1 Answer
Re: Discovery plus not working after changing package
@Jody2When moving from Sky Q to Glass/Stream all your Marketplace subscriptions are cancelled so you have to re-register (see the following link)  https://www.sky.com/help/articles/sky-marketplace-upgrade
You should be able to re-register as follows:
Go to the bottom of the home page and select the following in this order: MySky / your products / (enter your PIN) / App Subscriptions
Select App subscriptions / Current / and then Discovery+ Monthly.  Hopefully it will say £0 per month as you have Sky Cinema.  If so select Activate subscription.
Also see the link given by @MarkGoldsmith just above this post.
If you were a Sky Q customer, you need to resetup/relink your Sky and Discovery plus accounts, as when moving over to Sky Stream you will get a new streaming account and your old Sky Q account would be deactivated and thus unlinked from your discovery account:
https://www.sky.com/help/articles/sky-marketplace-subscribe-to-discovery-plus
