Discussion topic: Controller
Message posted on 26 Jun 2024 03:47 PM
Controller
Hi my volume up and down isn't working it come up with another menu the buttons are doing the wrong things on my remote
Message posted on 26 Jun 2024 04:03 PM
Re: Controller
@Ralph2001 wrote:Hi my volume up and down isn't working it come up with another menu the buttons are doing the wrong things on my remote
Follow the info here:
https://www.sky.com/help/articles/remote-control-help-sky-glass
Message posted on 26 Jun 2024 04:11 PM
Re: Controller
@Ralph2001If the troubleshooting link provided by @Padam_Padam doesn't resolve your issue you could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If it is still not working I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
