Discussion topic: Continue watching small tile
Message posted on 28 Sep 2025 03:54 PM - last edited: 28 Sep 2025 04:04 PM
When trying to go from small tile continue watching to large screen hitting select not working? Any help?
Message posted on 28 Sep 2025 05:24 PM
Re: Continue watching small tile
Hi @amagluglug It certainly should work and has been for me without issue. It sounds as though you might just have a software glitch so try rebooting your Glass by going to Settings > System Management > Resets & Updates > Restart device. It takes a couple of minutes to completely reboot and you will have a blank screen for a couple of minutes before the Sky logo appears.
Message posted on 28 Sep 2025 05:40 PM
Thank you. I don't loose my playlist etc by this no?
Message posted on 28 Sep 2025 06:42 PM
@amagluglug wrote:Thank you. I don't loose my playlist etc by this no?
No it's saved on the cloud
pull the plug for 5 if it's easier
