Discussion topic: Connecting via Ethernet cable
Message posted on 27 Mar 2025 08:02 PM
How many of you connect your sky glass tv via an Ethernet cable? I have 160mps fibre which I believe should be sufficient enough for Glass, I have considered upgrading to a 320mpbs package. I take it the Ethernet gets you a better connection?
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Message posted on 27 Mar 2025 08:10 PM
Re: Connecting via Ethernet cable
@Reevo87 Ethernet ports on Glass & Stream are 100mbps ports, however if wifi is unstable ethernet will give you stability, but if you use ethernet you do need to urn off wifi on the TV/Puck and restart the TV/Puck
From what I gather the maximum speed the TV can get is 100mbps regardless of what speed above this your broadband is.
However, an Ethernet cable provides a more stable connection. When I got the First Gen Glass the WiFi would lose connection frequently but once I got an Ethernet cable it rarely loses connection. I recommend it - don't forget to turn off WiFi in your settings though if you do use a cable.
Message posted on 27 Mar 2025 08:20 PM
What sort of Ethernet cable would you reccomend please? Just something bog standard
Message posted on 27 Mar 2025 08:26 PM
@Reevo87 wrote:How many of you connect your sky glass tv via an Ethernet cable? I have 160mps fibre which I believe should be sufficient enough for Glass, I have considered upgrading to a 320mpbs package. I take it the Ethernet gets you a better connection?
I've always run my glass tv from wifi and never had an issue ...... likewise 3 extra pucks dotted around the house.
Message posted on 27 Mar 2025 08:49 PM
Cat 6 or Cat 8 would be my recommendation.
Message posted on 27 Mar 2025 09:21 PM
I have both my 55inch sky glass tvs connected to the Internet by ethernet cables, i am on sky gigafast broadband full fibre broadband 900mps
Message posted on 28 Mar 2025 07:46 AM - last edited: 28 Mar 2025 07:47 AM
Cat8 is for 40Gbs server room interconnects: it's a little excessive for a 100Mbs chipset ; )
Message posted on 28 Mar 2025 12:17 PM
@Reevo87 any new Ethernet cable you can buy will be Cat5e or higher which can carry 1Gb/s for up to 100m. The highercstandards are more difficultvto run as they tend to be stiffer.
