Discussion topic: Compatible dvd player for sky glass
This message was authored by: Belinda4
Hi Please can anyone tell me what dvd player is compatible with sky glass?. Thanks.
This message was authored by: Jporch316
Re: Compatible dvd player for sky glass
Mostly any player you would buy from new .... I would suggest you get a blue ray player and if you were looking to cut costs there are plenty of inexpensive ones out there
@Belinda4
As @Jporch316 indicates, definitely buy a Blu-ray player (which can always also play DVDs) rather than an actual DVD player: those are now at least a decade out of date.
Personally I've had both of the cheapest  Blu-ray players previously stocked by Argos working fine on Glass (although a 4K player may be a better investment if you can afford one)
The current one on ours is a BDP-3700
Avatar for Belinda4
Thanks for the info , really appreciate it.
