Discussion topic: Can’t connect sky glass with activation code
Message posted on 02 Feb 2024 05:17 PM
When I enter the sky glass activation code in my sky account it says the error message"check your sky glass. If you're not connected please try again later" . Have tried resetting router and tv and used a few different codes but nothing works
Message posted on 02 Feb 2024 05:39 PM
Re: Can’t connect sky glass with activation code
I am having the same problem. I have only had the TV for 3 days. I've factory reset it and done everything that was recommended with no luck 😞
Message posted on 02 Feb 2024 05:58 PM - last edited: 02 Feb 2024 06:00 PM
According to the guidence published by sky. You need to power your Glass off at the wall and then try again. If it doesn't work you will need to contact Sky customer services (we are fellow subscribers).
https://www.sky.com/help/articles/setting-up-sky-glass-linking-unsuccessful
Additionally the perceived wisdom is that you shouldn't factory reset your Glass unless instructed by Sky, due to account linking issues which may need a back end team to resolve, so likely you will need to call them @LisaMarie1.
You can find the number on this page: https://www.sky.com/help/home - scroll down to need more help, click the drop down and you will see the contact number.T he forum software doesn't allow us to post numbers.
Hope you both get sorted
MikeAlanR
Message posted on 02 Feb 2024 06:07 PM
Thank you @mikealnr I will have to get into contact with them.
Message posted on 17 Jul 2025 12:18 PM
Did you get this sorted? I've been waiting two weeks now and still not having any joy! 😞
