Discussion topic: Booster for WiFi
Message posted on 19 Sep 2026 12:28 PM
Booster for WiFi
Message posted on 19 Sep 2026 12:36 PM
Re: Booster for WiFi
@johnnyalba wrote:
My skyglass is in my bedroom and the router is in my lounge. My bedroom is part of an extension which is causing issues with WiFi connection. Can you please advise?
We have no idea about the layout of your property.
Sky Glass has no engineer support - it is up to you, the customer, to troubleshoot your home broadband network in order to provide the TV with a fast and stable enough connection in order for it to receive the service.
If you have Sky Broadband then I believe boosters are available, depending on your package.
You are much better off sorting out your own network independently. Invest in a decent WiFi mesh system or perhaps try some powerline adapters in order to get the broadband signal from your router to your Glass TV as efficiently as possible.
