3
This discussion topic has been answered Discussion topic: Bluetooth
This message was authored by: StewartT1
Bluetooth
Devices that worked fine via Bluetooth on sky q box come up "not supported" on my sky glass. Why? And how can I did this
This message was authored by: BenJoBanjo Answer
Re: Bluetooth
Sky Glass uses Bluetooth for connecting the remote and for sending audio to external Bluetooth headphones. What are you trying to connect?
Sky Glass is a completely different type of service to Sky Q so you should never assume that just because something works on Q it will work on Glass.
Re: Bluetooth
Avatar for StewartT1
Re: Bluetooth
Trying to connect my mobile phone, Motorola and my wife's mobile phone Google pixel but both coming up as not supported on my sky glass. My Bluetooth headphones connect no problem. Was wanting to play my music through the tv system.
Re: Bluetooth
Hi @StewartT1 Unfortunately Glass currently does not support android phones being connected via bluetooth.  It only support Apple AirPlay for the connection of Apple devices. Whether or not this will be changed via a future update I don't know.
You may be able to cast/mirror to Glass via a third party device such as Chromecast etc. (try googling it so see)
