05 Dec 2023 07:11 AM
How do I get sky to connect at turn on. I get no connection message then I turn off and back on and it connects It. first attempt never connects even the walk past doesnt. I just get no connection or a screen showing all the lead and airial ports . Turn off and back on and its normal. Have reconnected router .Do I reset ? I have turned off at mains and back on again but no change and this has been going on for several weeks.
05 Dec 2023 07:42 AM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried turning the networked standby mode to ON in the settings.
05 Dec 2023 12:18 PM
I got a similar message, for the first time in two years, recently. The first message said "no service". I pressed the OK button on the remote and got the screen with the aerial and hdmi icons. I pressed the ok button again and got the Home Screen, and everything worked ok.
07 Dec 2023 08:46 AM
Yes have reset everything I can except completly resetting the TV. Have doubled checked all the settings
