This discussion topic has been answered Discussion topic: how far out does the sky glass swing out from the wall
Message posted on 25 Aug 2025 02:13 PM
HiI have recently fitted a 65" sky glass onto the wall. When attempting to tilt the TV it only swings out approx 11 degrees. Has anyone any experience of this. Can you buy a bracket that allows a bigger swing?
thanks
R
Message posted on 26 Aug 2025 11:00 PM
Hi @Glasgow1
See: https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
Sky Glass (both generations) are compatible with standard VESA wall mounts. However you need to ensure that it is rated for the weight as Glass units weigh more than standard TVs.
MikeAlanR
Hi @Glasgow1
MikeAlanR
