Discussion topic: Wall fitting
This message was authored by Lsmbsky This message was authored by: Lsmbsky
Wall fitting
Hi has anyone had there sky glass 65inch put on the wall in a new build property?
im worried it will be to heavy for the walls! I have messaged a few business who fit tv's and they've said the tv is very heavy so would have to use extra screws.
just wanting someone advice/recommendations would be grateful TIA x
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Re: Wall fitting
Hi @Lsmbsky
The TV is extremely heavy at  28kg so I would advise it's best to get a professional who will then decide what's suitable for fixing etc.
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
