Discussion topic: Tv wall bracket
This message was authored by: Brett19
Tv wall bracket
Hi Could I ask if the first generation sky glass tv wall bracket 43inch would fit the 65inch tv ?
This message was authored by: peter-marlow+1966
Re: Tv wall bracket
I don't  think  so as i believe  that the 43inch  bracket  will be to small  for the back of the 65inch tv, the gen 1 stand / wall was the right  size for that tv and that why you also got  the wall template  for that size  tv and wall bracket and if the 43inch  wall bracket  did fit the 65inch tv will probably  not take the weight  of it
P c marlow
Re: Tv wall bracket
If you  are  asking  about  a 65inch  gen sky glass  tv  the wall bracket  mountings on the back are completely different  to the gen 1, as the stand on the gen 2 are different  to the gen 1 tvs
P c marlow
