Discussion topic: The wall mount for my Sky glass 2 small 43” tv doesn’t swivel enough
Message posted on 10 Apr 2025 07:40 PM
I'm happy with my new Sky glass tv but the Sky wall mount is a huge disappointment. It hardly swivels, and I'm left with a tv that's not facing us
I'd estimate it swivels no more than 5 to 10 degrees, but I need it to swivel about 30 degrees. Previous wall mounts have done this easily
is there a workaround or a 3rd party wall mount for a glass 2 that would solve my problem?
Message posted on 10 Apr 2025 07:58 PM - last edited: 10 Apr 2025 07:59 PM
Re: The wall mount for my Sky glass 2 small 43” tv doesn’t swivel enough
I'm not familiar with the Glass mount but I do know that the Glass TV itself is compatible with generic VESA mounts, so if you find one that works it should be fine to use with Glass as long as it's rated for the weight of Glass.
