Discussion topic: Swivel tv bracket recommendation for 65 inch sky glass tv
This message was authored by: Jess__
Hi I am wanting to attach my 65 inch sky glass tv to my wall on a swivel bracket. Can anyone reccomend a tv bracket that will hold the weight of the tv please as I'm unsure of which one to get if this is at all possible. Thanks
Re: Swivel tv bracket recommendation for 65 inch sky glass tv
The  AVFJNL454 is rated to 60 Kg ... but the real issue is the wall construction suitable for such a mount🤔
@Jess__
As @Exiled-in-HH indicates, the wall is much more likely to fail than the bracket, unsurprisingly if you recall school physics lessons on the principle of application of force through a lever (which is what a swivel bracket basically is)
The considerable mass of a big Glass television on the end of a swivel arm does a very good impression of someone using a pry-bar on the wall bolts.
