8
This discussion topic has been answered Discussion topic: Stand
This message was authored by: Tash87
Stand
What are others putting their tvs on , I didn't no the mount didn't come with the gen 2 , I don't no what I'm going to put it on when it comes tomorrow
This message was authored by: GD1 Answer
Re: Stand
@Tash87  It comes with it's own stand.
Re: Stand
Avatar for Tash87
Re: Stand
  • I mean like a cabinet or something that will hold it , looks very heavy .
Re: Stand
@Tash87  Any decently constructed TV cabinet will support it with the exception of maybe a glass one due to the wieght.
Re: Stand
@Tash87 VESA wall mounts are compatible with Sky Glass, so long as you make sure it and the fittings can support the weight of the Glass.
My own 55" Glass Gen Two is on a wood and metal stand. I don't trust wall mounting a TV at all!
Avatar for Tash87
Re: Stand
Iv had a 55" on the wall for years moved it over the fire last January and it was gone b4 Xmas never again , is the stand that come with the tv flimsy.  I'll have to go cabinet shopping tomorrow,  thanks for your reply
Re: Stand
@Tash87  TV stand itself is solid enough, just make sure you follow instructions on inserting the prongs correctly.
Re: Stand
@Tash87 No, it's not flimsy. Just make sure you read the assembly instructions so the Glass is put on it the correct way round. It's a two person job though.
Avatar for Tash87
Re: Stand
Thank you 😊
