6
This discussion topic has been answered Discussion topic: Sound
This message was authored by: Sar_P
Sound
Just had sky installed and now the sound quality is horrendous 😐 all crackling and muffled. The bot said check viewing mode but I don't have that option! Can anyone help 😊
This message was authored by: Anonymous Answer
Re: Sound
Ok cool. Just so that you know, that's called a Sky Stream Puck. You might see people in this commmunity refer to that when helping you.
I think the first thing to do is to go to settings and in sound settings change the "digital output hdmi" or similarly named to Dolby Digital. If that doesn't make a difference try PCM.
Re: Sound
@Sar_P Is this a Sky Glass Gen 2 TV?
Avatar for Sar_P
Re: Sound
Hi
I really don't know 🤷‍♀️just says glass/stream.
Re: Sound
Is it a whole new TV or just a little box?
Avatar for Sar_P
Re: Sound
Just the box.
Re: Sound
Avatar for Sar_P
Re: Sound
Thank you 😊 😊 it worked.
