Discussion topic: Sound is very low
This message was authored by: Aracca
Sound is very low
Morning
my sound on my sky glass is very low when they talk, when they speak it's lower then the back ground noise and the adverts sound and music is higher
Re: Sound is very low
@Aracca
That would typically suggest the centre speaker isn't working, as it's the centre channel where voice is mixed in 5.1 audio.
You'll need to report the issue to Sky and get the set swapped out.
