Discussion topic: Sky glass wall bracket
This message was authored by: Deborah261
I have just purchased a 65"sky glass tv.  I forgot to order the bracket at same time.
does it need to be a sky tv  bracket or any bracket?
have tried to purchase on sky app but can't find it and it's a nightmare trying to speak to someone
Re: Sky glass wall bracket
@Deborah261
You can use standard VESA wall mounting brackets, but they need to be capable of safely holding the (excessive) weight of a 65" Sky Glass TV. Your best bet is to contact a decent TV installation contractor who can check the wall you want to mount on and provide advice on the best quality bracket to use.
