21 Jul 2023 04:25 PM
My sky glass remote not working I have tried changing batteries but no light at all I have followed the step pressing 4-6 for te seconds 7-9 for ten seconds and 1-3 and nothing is showing what to do please help
21 Jul 2023 11:25 PM
Posted by a Superuser, not a Sky employee. Find out moreTo help you try to get your remote working the links below are to remote troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. There was a faulty batch of remotes at the end of last year and this method often worked even though it sounds a stupid solution (it worked for me as well). Whether it will work on newer remotes I don't know but it's worth a try.
If none of the above works then phone Sky to discuss and request a replacement remote.
If you have one available you can use a Sky Q remote.
