Discussion topic: Sky glass tv loses connection with my broadband
This message was authored by: Rubymonday99
Each night my sky glass loses connection with my wifi It takes too long to re connect, why is this?
Re: Sky glass tv loses connection with my broadband
Change your Sky Glass TV to the following recommended settings set in Settings>
Set Network standby mode to ON and Overnight power saving to OFF.
Turn wifi OFF under Network if your TVs are connected via ethernet.
Once you have made the changes in settings above, do a settings restart straight away on your Sky Glass TV.
This ensures that the options are saved correctly.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Glass TVs will perform a reboot. It will take a few minutes to complete
