Discussion topic: Sky glass sound
This message was authored by: Lucy2014
Sky glass sound
Am having sound issues with my glass tv when they speak it's all out of sink
This message was authored by: Jporch316
Re: Sky glass sound
Hi
either flick channel back and forth or pause ....should fix it for a while
Avatar for Lucy2014
Re: Sky glass sound
It's been happening for the last week or so
Re: Sky glass sound
Have you tried pulling the plug for a few minutes? I've also seen out of sync voices on live tv channels in the last week normally happens after the ad breaks for some reason ...... I have noted the issue in the superuser forum and will keep checking if other users post here with a similar issue
