Discussion topic: Sky glass sound very flat
This message was authored by: Clairea0281
Hi, does anybody know why my sky glass tv's sound is very flat? As in no bass at all? Ive tried all the usual: reboot etc etc but no difference....??
This message was authored by: peter-marlow+1966
Re: Sky glass sound very flat
Have you checked the  sound settings
P c marlow
Avatar for Clairea0281
Hi, thanks for replying, yes we've adjusted the sound settings but nothing makes a difference.
If you are still in the warranty then  call sky and ask about a replacement
P c marlow
@Clairea0281 assuming you're new to Sky Glass, do you have a Gen2 or a Glass AIr?
Its Gen 1 but its sorted now. It's under warranty luckily so Sky are organising an engineer with a view to replacing it
