Discussion topic: Sky glass remote
This message was authored by Nayra This message was authored by: Nayra
Sky glass remote
I have changed the battery so many occasions does anyone else have the same issue. On the sky glass TV
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Sky glass remote
@Nayra The batteries in my remote only last me about 3 weeks whereas my Sky Q remote lasted over a year. I have read numerous post of the forum where people complain about having to replace the batteries all the time (some every few days).
There has been a suggestion that the low battery warning is inaccurate so I ignored it but my batteries were completely flat only a couple of days later.
I bought a load of cheap Amazon Basic batteries but I would suggest you contact Sky and request a replacement remote.  If you have one available a Sky Q remote also works with Glass or Stream.
If my post has solved your issue please mark as an "Answer"
This message was authored by Anonymous This message was authored by: Anonymous
I've had my equipment since September I have never changed the batteries in the Glass remote although it has little use and the Puck used frequently I've changed just the once.
