Discussion topic: Sky glass remote not working
This message was authored by: Dean471
Sky glass remote wont let me access the tv menu the circle button not working voice command works volume works changed batteries nothing tried reset with 7and 9 1and 3 doesnt work
Re: Sky glass remote not working
Try holding the remote in two hands and gently twisting it like you are wringing out a towel and see if that helps.
