Discussion topic: Sky glass keeps dropping WiFi connection and buffers a lot
Message posted on 15 Feb 2025 06:33 PM
Ever since I changed my internet provider I have had the issue where when I turn on my tv in the morning it won't connect to the WiFi until I have reset both router and tv and when I am watching it buffers a lot
my puc in my room works fine
all the phones works fine
ipad works fine
laptop works fine
my internet speed is at 311mbs
again this only started when I changed providers when I was with sky for internet not a single issue and it is only the tv that plays up
thanks
john
Message posted on 15 Feb 2025 07:04 PM - last edited: 15 Feb 2025 07:06 PM
Re: Sky glass keeps dropping WiFi connection and buffers a lot
Hi @Xerri
Try going into settings > startup and standby and ensure > networked standby mode in ON and overnight power save is OFF.
Re the buffering run a speed test in netflix to see what the puck is getting. It needs 25Mbps for HD and 30Mbps for UHD.
MikeAlanR
Message posted on 15 Feb 2025 07:07 PM
I've done all that
I have just tried splitting my WiFi to a split signal 2.4 and 5g. I am now running the tv on the 2.4 and nothing else to see if that works
