Discussion topic: Sky glass corner bracket
This message was authored by Mytchett89 This message was authored by: Mytchett89
I am getting a 55". Sky glass on Saturday   I would like to put on the wall in the corner. Can anyone please suggest the best bracket to use
This message was authored by mikealanr This message was authored by: mikealanr
Re: Sky glass corner bracket
Hi @Mytchett89
I don't have a specif bracket recommendation, however any VESA mount will work. You just need to ensure that they are related for the weight as Glass is heavier than a normal TV. 23kg for the 55 inch with out the stand.
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
@Mytchett89
Perhaps also keep in mind that for any bracket which isn't flush to a wall, the basic principle in physics of the operation of a lever becomes significant.
