03 Aug 2023 06:17 PM
Sky glass control not working. No backlight. Batteries have been replaced.
03 Aug 2023 08:04 PM - last edited: 03 Aug 2023 08:07 PM
Posted by a Superuser, not a Sky employee. Find out more@Garysarah211005 Try to pair the remote again as follows:
If that doesn't help then try the following troubleshooting guides:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. There was a faulty batch of remotes at the end of last year and this method often worked even though it sounds an unlikely solution. Whether it will work on newer remotes I don't know but it's worth a try.
If none of the above works then phone Sky to discuss and request a replacement remote.
If you have one available you can use a Sky Q remote while you wait for the replacement..
Good luck 🤞
