Discussion topic: Sky glass and sky Q 2 banners
This message was authored by Jill This message was authored by: Jill
I have a sky glass tv linked to a sky Q box. However there are 2 banners appearing at the bottom of the screen as though the 2 systems are working at the same time. I had heard that I needed a sky touch remote however when requested this from sky it was refused
Re: Sky glass and sky Q 2 banners
@Jill
Sky hasn't made a touch remote for several years: those were only produced for the first couple of Q box models in 2016-18.  For Glass televisions without a Sky subscription there's a version of the Glass remote without Voice Control, and with dedicated buttons for YouTube and Netflix.
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@Jill have you disconnected the Sky Glass TV from the internet?
Exiled in HH
Jill
I haven't will that help ?
This message was authored by Jporch316 This message was authored by: Jporch316
@Jill
The problem you have is that the q remote also works via IR with the glass tv. Some users actually use the old q remote with the glass instead of the supplied remote. The glass remote is Bluetooth connected.
there was a thread on here going back a year or so that had a fix for this issue. Unfortunately with so many threads on here regarding remotes I'm having trouble finding it.
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
Is the banner info obtained via the internet?
Exiled in HH
