Discussion topic: Sky glass and channel5 PIN
Message posted on 21 Oct 2025 10:13 PM
Sky glass won't let me watch Channel5 without a Pin but I have no pin, tried to go to help on channel 5 website but that needed a code from the tv, which I was not getting either
Message posted on 22 Oct 2025 12:22 AM
Re: Sky glass and channel5 PIN
Hi @Hoppingjay I don't think I have ever been asked for a PIN for Channel 5 but if are asked again try your default Sky PIN number which is the last 4 numbers of the phone number you have registered to your Sky account (unless of course you changed it in settings).
If it is the Channel 5 App that is asking you to sign in you could also look in the Settings > PIN & Parental menu and go to PIN for Apps. Select this and then look for My5 to make sure it is not set to the on position.
Message posted on 22 Oct 2025 07:50 AM
It was Channel 5 asking for Parental control pin but as my children are over 40 I don't have any controls set. All sorted now, more by luck than knowledge by using my gotopass number , not my phone number.
