Discussion topic: Sky glass 43 gen 1 IR code for fire stick
This message was authored by: Mike738
New fire stick is stuck at the set up stage because I can't find the right IR code for a sky glass 43 inch.
does anyone please have any alternative codes I can use.
thanks
Re: Sky glass 43 gen 1 IR code for fire stick
Hi @Mike738 I'm not sure what this has to do with Sky Glass or Stream but I've never seen an IR code for a firestick.  Mine is just plugged into my TV via an HDMI port and then connected via WiFi to my router.  In addition it is plugged into a power socket as the TV HDMI does not have sufficient power. I have never had to connect the remote by IR or bluetooth, it just works.
Avatar for Mike738
You're lucky then because mine doesn't. It's stuck half way through the set up where it tries to control the TV volume but won't. I can't get past that page or cancel it, it just keeps getting stuck at the same point as it can't control the TV.
the only option is to open advanced settings at which point it asks for an IR code for the TV which is the reason I'm asking in here, to see if any one knows it.
@Mike738  Have you tries a hard reset of the remote.  This LINK gives a fairly comprehensive description of the procedure.
Good luck.
Avatar for Mike738
I will give that a go, thanks
