08 Nov 2023 07:52 PM
My Sky Glass remote is not working,, the voice control doesn't work and I cannot adjust the volume. When I press volume the search/subtiles/audio options bar comes up instead.
09 Nov 2023 06:34 AM
Posted by a Superuser, not a Sky employee. Find out more@AinbrayTry pairing the remote again as follows:
If it is still not working I would request a replacement at the following link:
Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
09 Nov 2023 08:27 AM
@Fothergill1 Thank you so much for your advice. I have tried the reset option several times but no success. I think I will have to go for a replacement. We did have a Sky Q remote but had to send it back with the box when we got SkyGlass. Thanks again.
09 Nov 2023 08:33 AM
@Fothergill1 Just tried link to replacement remote but page not available unfortunately.
09 Nov 2023 01:08 PM
Posted by a Sky employeeHi there, @Ainbray. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
09 Nov 2023 01:41 PM
@Addie15 Thank you Addie15.
09 Nov 2023 03:17 PM
@Ainbray wrote:@Fothergill1 Just tried link to replacement remote but page not available unfortunately.
That's strange as I just tried the link and it asked me to sign into My SKy and then produced the form populated with my details.
Anyway I see your issue has now been escalated so you should get sorted. 😀
09 Nov 2023 08:51 PM
@Fothergill1 Thanks for checking back in! It might be because I'm a Republic of Ireland customer. They kindly redirected me and have told me they will send a replacement.. Thanks again 🙂
09 Jul 2024 08:50 PM
Getting exactly the same. + button turns the tv off as well for me. Cant control the volume as just keeps coming up with the menu screen Tried resetting multiple times, no luck. Sky Glass is actually not very good.
