Discussion topic: Sky Glass and Puck remote too painful to use
This message was authored by Gem+S This message was authored by: Gem+S
I have rheumatoid arthritis and fibromyalgia. I find the Sky Puck and Sky Glass remote too painful to use. Yes I know there is voice control, which I use a lot but for a lot of functionality like the tv guide and favourites etc I need to still use the remote for some things. Does anybody know if I can use another universal remote which has softer pressing capabilities on the remotes traction within the keys so I'm not in agony every time I use the TV remote.
Re: Sky Glass and Puck remote too painful to use
@Gem+S  I'm not sure if the existing accessibility remotes would work with Glass/Stream, however it may be worth getting in touch with the accessibility team to see if there is a suitable remote.  https://www.sky.com/help/articles/accessibility-remotes
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Gem+S
I don't know if it would be any better but if you have one available you could try a Sky Q remote which works perfectly well with both Glass and the Stream pucks.
If my post has solved your issue please mark as an "Answer"
