Discussion topic: Sky Glass Whole Home
This message was authored by: ZPer
If I no longer use the Sky Puck and only use Sky services on my one Sky Glass do I need whole home?
This message was authored by: peter-marlow+1966
Re: Sky Glass Whole Home
If you  are not watching  sky in any other  room then on you don't  need  whole home
P c marlow
@ZPer  You would not need a Whole Home subscription but you would need to cancel the stream Puck and Whole home with Sky.  If the puck is Sky owned then you would have to return it but they will send you the necessary packaging.
