Discussion topic: Sky Glass Air or Sky Gen2
This message was authored by: Jporch316
Find out more
Message posted on 02 Jul 2025 07:02 AM
Re: Sky Glass Air or Sky Gen2
My two pennies worth .....
if you already have or are thinking about getting a separate sound system then air will do. If not glass has serviceable built in sound for most rooms . I went from 43 to 55 glass and after a day of getting used to the size difference I would now never go back !
if your router is in the same room as the tv then I would try WiFi to begin. The system is built for wifi and if you have a good speed and a solid signal you ll get no problems at all and no cables.
