4
This discussion topic has been answered Discussion topic: Second hand Sky Glass compatible with Sky Q
This message was authored by: boyrollo
I currently have SKY Q with several boxes one of which is hardwired into my garden bar, I have the offer of a sky glass TV and wondered if it would be compatble with the current Sky Q set up I have. This would be used in the bar instead of the current TV and mini box
any help appreciated
Re: Second hand Sky Glass compatible with Sky Q
@boyrollo
Sky will not permit subscription to Q and Glass service at the same address: if you were going to acquire that Glass television set you would be using it as a somewhat inflexible semi-smart display panel (albeit one with multiple speakers) for a Q Mini box.
@boyrollo
This message was authored by: lfcsab
If the sky glass tv was bought second hand from fb marketplace for example, would you be able to just plug in your sky q box and use it like a normal oiled tv?
hi @lfcsab
Yes, but there are a few settings you need to change as outlined here: https://www.sky.com/help/articles/connect-q-to-glass
MikeAlanR
Note that Glass is not OLED.
