Discussion topic: Remote
This message was authored by: Jadeblaz
Remote
My sky remote has stopped workin
Re: Remote
Contact Sky and ask for a replacement ..... do not buy one .... first try some new batteries😉
Re: Remote
@Jadeblaz  The links below are to remote troubleshooting guides and may help you.
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine on two occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you have one available you can use a Sky Q remote while you wait for a replacement.
