Discussion topic: Remote not working
This message was authored by Michael+1986 This message was authored by: Michael+1986
Remote not working
My remote for sky glass not working tried everything took batteries out and put back in certain buttons will work ie the volume but not others
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Re: Remote not working
Hi @Michael+1986
Try resetting the remote, firstly press and hold 4 & 6 for around 10 seconds, then press and hold 7 & 9 for around 10 seconds.
Then attempt to pair by pressing and holding 1 & 3 until the message appears on screen.
If that doesn't solve it use the link below and on select 'No, I still need help' on the last page.
https://www.sky.com/help/articles/remote-control-help-sky-glass
If you have an old Sky Q remote you can pair that by pressing and holding 1 & 3 until the message appears.
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
This message was authored by CRDHEFE This message was authored by: CRDHEFE
I tried all the sky help tips and advice given previously when ringing helpline, including turning off Internet.
This was attempted again and again over 2 hours.  We have had sky stream since December and this is a repeated problem on only 1 of the tvs with a puck.
Last resort was 'wringing' the remote as said on here.  Instantly worked.  Thank you for advice
