Discussion topic: Remote control problems.
Message posted on 19 Oct 2024 10:08 AM
The sky glass remote turns Samsung TV on and off. I managed to set it yo flash the sound bar volume light but the volume doesnt change. The old sky Q remote still works fine.
Any ideas?
Message posted on 19 Oct 2024 11:19 AM
Re: Remote control problems.
Is your soundbar connected via Glass's e-arc output? It doesn't currently support all soundbars. Hopefully that will change in future releases.
Message posted on 20 Oct 2024 09:01 AM
@SueandNeil I have a Samsung S90C TV and HW-Q600 CXU soundbar and can control the volume on both through my Stream remote. If your are nrelatively new models they you shpould be able to control them. My soundbar is connected to the TV using the e-arc HDMI socket
