Discussion topic: Questions about Whole Home with second Sky glass
This message was authored by: Dazzasky
Re: Questions about Whole Home with second Sky glass
@SquareEyes86 wrote:
Can you pause live tv on one Glass and pick up on the other easily? If so, how do you get to the paused live tv picture on the second Glass TV?
You can but you may have to wait a couple of minutes for it to sync over. @SquareEyes86
Avatar for SquareEyes86
Level 3 icon
This message was authored by: SquareEyes86
Thank you for answering this. After it has synced, how do I pick up the pause on the second Sky Glass? Is the pause the first thing I see on turning the TV on or do I get to it via an option on the screen?
This message was authored by: Jporch316
Via the continue watching rail ...... wherever you have stopped the show it will appear at thbfromtof the continue watching rail with a little blue marker underneath showing how much of the episode has elapsed
can also do the same via the main playlist
NB not convinced this will work on live tv ......
This message was authored by: Yoghurt
@SquareEyes86  Definitely keep the pick then
Sarah backx
This message was authored by: Janoid19
Hi, I am thinking of adding a 2nd sky glass to our house. I am getting mixed responses in if I need a sky puck or not? If I have a sky glass in the front room and get a 2nd sky glass for the kitchen, do I need to plug a puck into the 2nd tv or not?
If you are purchasing a Glass you do not need a sky stream puck. The puck is designed for those that do not wish to buy a TV from Sky.
Thank you! The information out there is so confusing.
