Discussion topic: Problems with attaching metal rods to Sky Glass Air tv stand..Do you need to force them down before
This message was authored by: Dave19601
Having problems assembling my Glass Air TV stand. Do you need. to force the metal rods on to the stand platform, before twisting ( locking) them?
Re: Problems with attaching metal rods to Sky Glass Air tv stand..Do you need to force them down bef
Hi @Dave19601 , the rods just need to be placed in the holes in the stand and then twisted in however if you happen to have the rods the wrong way round you won't be able to twist them to lock them in place.
My suggestion if the pegs aren't locking, take then out, rotate them slightly and put them back in the hole and try to lock them. Eventually you will then get the rods the correct way round.
