Discussion topic: Picture quality
This message was authored by: Tucker23
Picture quality
Just updated to sky stream and all the channels seem to have lagging pictures/bad quality/jittering/pixakted images... checked all connections and says it's all fine so not sure what the problem is?
Re: Picture quality
Hi @Tucker23 is this on apps too or just live TV?
The place to start is to measure your speed, here's a quick guide. Could you report back with what speed you're getting please?
  1. Open the Netflix app on Sky.
  2. Go to Get Help in the sidebar.
  3. Select Check Your Network.
  4. Note the download speed displayed.
Avatar for Tucker23
Re: Picture quality
Hi, apps seem to be down. Just done the steps as you posted and connection speed is 102.51mbps
Re: Picture quality
Good stuff, assuming that doesn't fluctuate a lot that's a good speed to have.
Have you tried restarting to see if it solves anything?
  1. Go to Settings
  2. System management
  3. Resets & updates
  4. Restart device
