Discussion topic: PS5 audio settings with sky glass
This message was authored by: CrazyCraigR
Message posted on 03 May 2025 11:03 AM
What should I have the HDMI device type set to on my PS5 settings using sky glass should it be on TV or soundbar as technically the speaker is a soundbar but then the device is a TV.
This message was authored by: CoffeeDrinker
Message posted on 03 May 2025 01:49 PM
Re: PS5 audio settings with sky glass
I'd gpo with soundbar. The TV setting likely restricts dynamic range (the difference between the quiestest and loudest sounds) and low end bass signals that would like cause cabinet rattling and distortion through your typical TVs built in speakers. The sound system on Glass can cope with a reasonable amount of dynamic range.
Sky Glass & Stream Puck customer w/Sky Entertainments & Netflix, Sky Cinema, Whole Home & UHD/Dolby Atmos add-on.
