Discussion topic: No wifi for sky glass
This message was authored by: Sylvia531
Not good with technology,  just got sky glass a week ago now having issues with the WiFi. All the checks say WiFi is ok, but the tv is not. Comes up on TV technical issue. How do I get it sorted  bearing in mind Im female in my 70's!!!
This message was authored by: 82bit
Re: No wifi for sky glass
If your router is close enough, plug the Glass TV directly into one of the LAN ports via an Ethernet cable if you have one. It'll save you a world of pain messing about with WiFi.
Sky Glass 65” [Gen 2]
Sky Glass 43” [Gen 1]
Sky Stream Puck x4
Sky Ultimate TV, Sky Sports, TNT Sports, Sky Movies, Kids, Whole Home, UHD&Atmos, Ad Skipping
Sky FTTP
Sky Mobile SIMO x7
The checks may say that WiFi is OK, but the crucial thing with Sky Glass is that the WiFi connection to the TV needs to be fast and stable.
What broadband speed are you paying for? Is it from Sky? Were you sold the Glass TV by someone who didn't check what broadband speed you actually have?
Sky Glass will not work well if your broadband speed is anything less than 25Mbps, but it ideally needs to be a lot more.
This message was authored by: Jporch316
Hi @Sylvia531
@either pull the plug for a few minutes or restart the tv from within the settings menu ... sometimes clears the error message
