Discussion topic: My sky glass tv screen is not working - display is corrupted
Message posted on 03 Sep 2024 01:28 PM
Hello. I am on my second Glass TV. The first was replaced in July because the panel displayed lines across the screen.
Yesterday the replacement TV began malfunctioning. The panel again is not displaying correctly. Flickers and is bright then dark. I have left it turned off overnight and no change. I have also pulled the power and left it off for over an hour and again no change,
I have attached a couple of photos.
Message posted on 03 Sep 2024 02:05 PM
							Re: My sky glass tv screen is not working - display is corrupted
Hi @indie1776
We are fellow subscribers here on the forum. You will need to follow the same process as you did previously to get a replacement under warranty or you can make the case to return the TV.
Lines down the screen can be caused by software issues and usually leaving it switch off for a while resolves it's however flickering sounds more like a hardware based issue.
You can make a complaint to Sky as per the information here: https://www.sky.com/help/articles/how-to-make-a-complaint
MikeAlanR
