This discussion topic has been answered Discussion topic: My Sky TV remote control stipped working for 3 days now even after changing its battery. Just nought
Message posted on 04 Apr 2024 01:25 PM
My TV remove is not working for 3 days now despite changing its battery. It can on power, red light comes on, but all other buttons on the remote are not responding. I just bought my Sky Smart glass TV January 2024
Message posted on 04 Apr 2024 02:11 PM
Take a read of the following:
Reset the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Reset the remote
