6
This discussion topic has been answered Discussion topic: MOTION SENSOR
This message was authored by: Simon92
MOTION SENSOR
It was suggested in the thread "You've purchased and received your Sky Glass Gen 2, what are your thoughts on how it performs?" that the motion sensor which switches the set on is fixed. However I have read elsewhere that in Settings it is possible to switch the sensor off. I have a number of issues to consider before deciding whether or not Sky Glass is right for me but frankly if it is not possible to stop the screen switching on any time there is movement in the room that will be a deal breaker. Surely it is possible to override this feature. Can someone confirm the position on this point for me pelase? Many thanks.
This message was authored by: Fothergill1 Answer
Re: MOTION SENSOR
Hi @Simon92  I no longer have Glass as I now just use the stream puck.  I can confirm that the "Wake using Motion" feature can definitely be turned off as I did so on my Glass.  There are a number of these gimmicky functions in the Start Up & Standby menu.  I turned them all off except for the Networked Standby Mode and this resolved menu of the issues I initially had with Glass.
Re: MOTION SENSOR
Avatar for Simon92
Level 3 icon
Re: MOTION SENSOR
Any particular reason for switching to the puck? I "think" I am close to things swinging on the neatness of Glass (no set top box or puck and inclusive soundbar) against what seems to be the overriding view that the picture quality of a decent OLED beats Glass. Would appreciate any comment on your switch from Glass to Stream.
Re: MOTION SENSOR
@Simon92  I lost my access to a satellite dish in July 2022 and at that time there was no option to have a stream puck on its own so my only option was a Glass TV (my son got a gift of a great LG OLED TV).  The picture quality of the Gen 1 Glass TV was nowhere near as good my my old OLED but to be fair it improved considerably with various software updates over the 16 months I owned it.
In November 2023 I took advantage of the Black Friday deals and got a new Samsung 65 inch OLED TV and soundbar at a great price.  With the  discounts it was was about the same price as a 65 inch Glass TV but the picture quality and viewing experience was outstanding.
Although I have not yet seen the new Gen2 Glass I believe the picture quality and sound have been improved but doubt it would be as good as my current setup.  Obviously it is a personal choice  but I have never regretted my decision.
Good luck with whatever decision you make.
Avatar for Simon92
Level 3 icon
Re: MOTION SENSOR
Thank you so much for this.
Avatar for Simon92
Level 3 icon
Re: MOTION SENSOR
@Fothergill1 Thank you so much for this.
Re: MOTION SENSOR
As a Gen 2 customer I can confirm the motion sensor can be turned off via the Settings menu.
The picture and sound quality is an improvement to Gen 1.
Answered - Go to Answer
