Discussion topic: Issues with sky glass
Message posted on 01 Jul 2024 04:39 PM
We have had sky glass since last July, within 2 weeks I rung sky to complain about (what I thought at the time was) the internet. After numerous calls and resets of the sky glass tv and broadband etc it would work. At this point I should say that our sky glass would just hang or skip, particularly with channel 4 app. In November I called again(my monthly complaint) and they said that my internet was not good enough and needed the super fast fibre connection. After waiting until march to get it fitted we finally had it done and still problems with connection to the tv and the channel 4 app but also
netflix. Called again in june and was sent a replacement router. Although it made the internet faster on other devices still not sorted out sky glass issue. Finally they replaced the sky glass tv, fingers crossed is seems a bit better, however my question is (finally, long story I know) we still have issues with channel 4 app where every day we will lose the ability to pause and rewind etc, and have to do a software reset on the tv to get it to work again. Has anyone had any positives with sky glass? We had sky q before this and never had a problem. I stupidly wanted to upgrade to sky glass, but I really wish I had never ever done it, let alone the extra costs etc (now up to £99 a month with broadband) just on basic package with Netflix, no sports or cinema etc.
I have heard you can go back to sky q and just use the sky glass tv as a slave device to show it. Any thoughts? Although if I hadn't got into a contract with the sky glass tv I would send it back!!!!
Message posted on 02 Jul 2024 08:25 AM
Re: Issues with sky glass
Are you including purchase of the TV in that £99?
The Sky TV service + BB should cost anywhere near £99🤔
Can you confirm your internet connection speed measured using the Netflix network check on the Sky Glass TV?
Message posted on 02 Jul 2024 08:32 AM
Yes that covers the £19 a month for the tv. Netflix speed check averages out at 60mbps.
Message posted on 02 Jul 2024 08:50 AM - last edited: 02 Jul 2024 08:51 AM
So you are paying £80 for Sky TV and BB?
That seems excessive🤔
Connection speed seems adequate. Do you have a backup streaming device does the 4 app run better on that?
Message posted on 03 Jul 2024 07:18 AM
Yes am running channel 4 app on laptop and that is fine. I will definitely be looking to either go back to sky q or leave sky completely on January as i think we are paying too much and they have not been very forthcoming with compensation for nearly a years worth of poor service.
Message posted on 03 Jul 2024 07:52 AM
Do you pay for ad skipping ... the only compensation with regard the 4 app would be very very small dependent on Sky's payments to Channel 4 to alllow fast forwarding through Channel 4's ads🤔
Message posted on 03 Jul 2024 09:17 AM
yes we do have add skipping.
i think i will just look to remove all of it after JAnuary and be left with basically a very posh monitor!
Message posted on 03 Jul 2024 10:44 AM
In the meantime get a Streaming device ... so you find out if you can run apps without issues😉
Message posted on 26 Jan 2025 09:38 AM
Buying a Skyglass is the biggest regret. A lot of problems with apps, not uploading programmes available, constantly needing updating or switching itself off or cutting programmes off suddenly. Would NOT recommend
Message posted on 11 Feb 2025 03:23 PM
I totally agree, it's definitely a step backwards from Sky q. Real issues with the Playlist playback, sometimes it will rewind, pause and go forward and sometimes it just won't. We've lost loads of programmes mid way through and the only way to try and get them back is via the approriate app, but the most current episode is unavailable until maybe the next day! Really inconsistent
