Discussion topic: I have sky glass and it is constantly buffering
This message was authored by: Tina881
For the past 5 days my sky glass tv is buffering consistently when we are watching channels programmes are taking long lengths of time to download
Re: I have sky glass and it is constantly buffering
@Tina881  How is the Glass TV connected to your router?   How fast is the speed reaching the TV?
Open the Netflix app on the Glass TV, go to Get Help, run the connection test and  post the speed result.
Avatar for Tina881
Speed is 18.93 bps
@Tina881
Sky recommends 25Mbs minimum for Glass in HD, and 30Mbs for UHD.
Avatar for Tina881
Thanks for your reply how do I increase the speed
This message was authored by: Jporch316
How fast is your internet connection listed as ?
if it's lower than 30mb you are going to struggle and you will need to contact your ISP and find costs on a different connection speed  ..... if it's higher you may need to connect using ethernet cable or powerline adapters
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
